silver90
#1 Posted : Thursday, October 20, 2016 11:14:35 AM(UTC)
silver90
Yesterday, I changed the water filter on my Frigidaire FRS6HF55KM1 and ran enough water out to get rid of the air in the line. About 30 minutes later crushed ice started coming out on its own. I pulled the ice bucket out, swapped it to cubes, but nothing stopped it. After swapping to cubes, the control panel locked up and would not change to anything else. The auger was rotating the whole time unless I opened the door. I had an appt. and had to get ready to leave. I also took the water filter out to stop the flow of water just in case. Before I left the auger stopped. I understand it times out after about five minutes. I went ahead to the appt.
When I got back, I inserted the water filter and ran water through again. The controls seemed to work so I put the ice bucket back in. However, went I pushed the crushed ice paddle, water came out. I'm not sure if the water filter is a coincidence or if it induced a failure. I assume, I need a new part, but I'm not sure what. Your help will be appreciated.
