My belt drive washer will not spin. I have checked the wig wag by switching the wires and it spins on agitate. No agitate on spin. I put the wires back and no spin but it will agitate. I have checked with a volt meter no power to the spin selenoid. Continuity is good all the way from the timer switch. Anyone have any ideas? I just checked with a volt meter and there is no power from the timer switch to the spin selenoid wire. Everything else works tho?
Thank you
Groups: Expert
Joined: 7/27/2010(UTC) Posts: 1,395 Location: near the middle of nowhere Was thanked: 24 time(s) in 24 post(s)
Pull the timer and check for burnt up contacts.
