zzapp
#1 Posted : Sunday, October 2, 2016 1:43:42 PM(UTC)
zzapp
Recently, my microwave has begun a rather unique issue. Everything seems to be working just fine (heat, and all features, etc.). However, when the cooking cycle is done, I get the beep, but when I open the oven nothing works - lights out, panel totally inoperative. (Note: it doesn't always do this, but now more often than not). So far, I can get by this issue by hard reset (unplug, plug). I would really like not to have to replace this unit, but I'm wondering if in the long run I might be better off doing just that.
I'm not that electrically nor mechanically inclined. If I do have to replace, is there another GE 1.7 cu ft model that would have the same mounting frame configuration. Dimensions of this unit are 30x16x15 (more or less).
Kind thanks.
Microwave circuit board in GE over the stove (Microwave Repair)
by JimmyT 8/29/2009 11:46:52 AM(UTC)
