Staticstation
#1 Posted : Sunday, September 25, 2016 7:13:32 AM(UTC)
Staticstation
I have a GE GDTP490EDWS dryer that I bought about two years ago. It will run for a few minutes then shut off. I have thoroughly cleaned out all of the lint. I'm assuming it is a thermostat but not sure which one. Any help on this? Any way I can check the thermostats to see which ones need replaced? I don't want to spend $200 on thermostats on a $350 dryer.
Any help is greatly appreciated. Thanks
cbmserviceguy
#2 Posted : Monday, September 26, 2016 10:25:23 AM(UTC)
cbmserviceguy
Would you mind checking your model number and reposting it? It's not coming up as valid. If you can get me that, I can point you in the right direction. Sounds like a cycling t-stat to me. It does heat at first right?
Staticstation
#3 Posted : Monday, September 26, 2016 4:16:26 PM(UTC)
Staticstation
Sorry the model number is GTDP490EDWS. Yes it heats up at first. Usually on the tried or fourth restart it will finish the load.
