I am replacing the high limit thermostat. How do I remove the bracket holding the thermostat - see attached picture. Should I push it in or pry it out? I tried pushing it in but it is too hard to do so. Is there a tool that I can use to easily remove the bracket? sorry the picture is upside down cb_bar@yahoo.com attached the following image(s):
