I called up the company that made the fridge, it is Danby, but they brand is Simplicity and both the fridge and the fan part seems to have been discontinued. I snapped a picture of the label on the fan. It is REALLY loud, 82db inside the freezer. I don't know if fan motors are proprietary to specific brands or others that might work. I tried googling the information on the label but no dice... I'd really appreciate any help!
your model is an apartment size or mini fridge as the model number shows. Just Google your model number and go from there. there are U.S. and Canadian sites that have parts, you may have to check a few, I hope this points you in the right direction.
I found the part. I was googling the brand and the model # instead of just the model.
