I have a GE fridge (TPS24PI) in which the evaporator fan motor has died ( good applied voltage at the source, no continuity across the motor). The motor is part number wr60x10009, which has been discontinued. Can anyone help me identify a replacement motor that will fit this fridge? I can probably rig up a way to make a new motor connect to the existing mounting bracket so that's not the primary issue. I think this motor has two speeds, but I am not certain. I would really appreciate any help/advice. It would be a waste of money to replace the entire fridge because of this motor. Thanks.
