Just ordered new part for Samsung dryer(cover-filter(u):graceDR Can the dryer be used while i wait to install this part
Joined: 6/13/2014(UTC) Posts: 781 Was thanked: 1 time(s) in 1 post(s)
Your speaking of the little flap that springs up when your remove the filter? I don't see why that would prevent you from using the machine.... I would recommend having your dryer vent system and duct-work thoroughly cleaned after you replace it. For that matter it's always a good practice to clean the vent system and ducting every 1 to 2 years depending on use.
