Gservi
#1 Posted : Thursday, September 1, 2016 6:30:28 PM(UTC)
Gservi
I have water coming from roof of Refrig just behind temp control panel and light. Any idea what things to test for, look for or what is typically the issues
#2 Posted : Friday, September 2, 2016 5:50:47 PM(UTC)
Very likely the cause of the problem is clogged drain in the freezer.
Unplug the refrigerator. Remove the rear panel inside the freezer and check the drain hole in the drain pan (#622 on the diagram) under the evaporator coil. If it's frozen up, you can unfreeze it using a hair dryer. Then put some hot water through the drain to make sure everything goes right.
Gservi
#3 Posted : Tuesday, September 6, 2016 10:56:37 AM(UTC)
Gservi
Hi Gene,
thank you for your reply. Nothing visible blocking the drain. I did as you suggested and poured hot water down just in case. Unfortunately the build up is still occurring. Any other ideas what could be causing the water to build up on the roof of the refrigerator?
thank you,
glen
