Leona Marie
#1 Posted : Wednesday, August 31, 2016 10:17:05 AM(UTC)
Leona Marie
Sensor or indicator doesn't appear to be functioning. Dial can be manually moved to rinse and then spin, but won't do so on its own. Thank you!
brobriffin
#2 Posted : Saturday, September 3, 2016 11:13:29 AM(UTC)
brobriffin
Man
United States
If I understand your complaint you are saying that the timer does not advance on its own but if your turn it manually the washer works. If this is the case you need to replace the timer, here is the part you might need.
Whirlpool WP22004380 Timer - AppliancePartsPros.com
Do not be confused by the Whirlpool part name, as they now build and provide parts for Maytag.
