Hello,
The oven for my gas DCS range is sort of working. Here is what is going on:
-I turn on the oven to 350 -Nothing happens for 10-20 minutes -Gas ignites for maybe 30 seconds and then stops -Wait about 20 minutes -Gas ignites again for 30 seconds and then stops -Oven never gets past 250
Interesting observations: -If I turn the flow of the gas to the oven on and then off the oven gas will sometimes ignite. Not all the time, but sometimes.
I can see the ignition rod glowing red hot.
If there are any suggestions on how to keep the gas flow constant to the oven, then I would greatly appreciate them. All top burners work just fine.
Thanks,
Dave
