Digital control for oven and clock seems to have gone out. There is no tag or sticker anywhere that shows model or serial number. Need help finding this information out so I can see about ordering a new control. The cook top burners work fine and the oven light works fine, but the digital clock and the oven do not work. They were just working so I can only assume that it's the control itself. Thanks in advance!!! itsanss attached the following image(s):
GE Model no. 164D2851P006 Eaton Model no. 14GL43344Y WB27X5524
If you take it apart there will be a part number on the side of the control. Best thing to do is get that number, plug it in and if it's been replaced follow the crumb trail to the latest version.
