AppliancePartsPros.com
Appliance Repair Help
Dryer Repair
Motor won't come on at Low or High heat settings
Dryer only powers on (drive motor spins) on cool down settings. No power to motor at Low or High heat settings. Have continuity at thermal fuse. Have both legs AC (120/240), pulled cycling thermostat and have continuity at large terminals at room temp. Heated thermostat until it clicked to open, no continuity and large or small terminals.
Looking for guidance as to next items to check?
RESOLVED:
Disassembled the timer/switch assembly and found a broken tang on one of the cams that actuated the electrical contacts. For troubleshooting purposes I super glued the cam back in place and tested. Up and running.
Dryer Repair
