spthomas1966
#1 Posted : Wednesday, August 24, 2016 6:49:34 PM(UTC)
spthomas1966
I have a lot of condensation forming around the water filter housing and odor filter housing. I thought at first that it was water leaking from the filter and/or the water line, so I removed the filter and shut off the water line to the fridge, but the problem persists. Over a typical day, about a tablespoon of water forms along the bottom edge of the filter housing and drips onto the shelf below. I've checked the seal of the door gaskets and they look good, so I don't think it's humid air getting into the fridge that's causing it. Other than this, the fridge seems to work ok, keeping temperatures as set on the panel. My concern is that the filter housing now has signs of rust and mold inside, which may pose a health risk with mold spores circulating inside the fridge. For those familiar with this model of fridge, the filter housing extends around the back of the fridge where the odor filter is located, and around to the left where the damper is located. Condensation collects along the bottom edge of these areas too. Any ideas?
