I have a Jenn-Air (Maytag) oven model number JMW953DAS. The oven fan is making noise so I replaced the fan in the rear of the oven. That did not solve the noise issue so now I have ordered the fan in the Control Panel, identified as the Tangential fan, part number AP6011041, made by Whirlpool. My question is how does one replace this fan? (Apologize for the bold font, not sure what happened)
I'm having similar issue with vibration noise that seems to be coming from the Fan Tangential of my Jenn-Air JMW9530DAS.
Did replacing the Fan Tangential fix you issue?
Thanks, Mark
