Tommy Graham
#1 Posted : Sunday, August 21, 2016 1:31:38 PM(UTC)
Tommy Graham
Replaced water filter and now the water dispenser won't shut off.
#2 Posted : Sunday, August 21, 2016 2:50:27 PM(UTC)
After installation of the new water filter, the water system needs to be flushed. Use a sturdy container to depress and hold the water dispenser lever for 5 seconds, then release it for 5 seconds. Repeat until water begins to flow. Once water begins to flow, continue depressing and releasing the dispenser lever (5 seconds on, 5 seconds off) until total of at least 3 gallons has been dispensed. This will flush air from the filter and water dispensing system. As air is cleaned from the system, water may spurt out of the dispenser.
Tommy Graham
#3 Posted : Tuesday, August 23, 2016 4:08:28 AM(UTC)
Tommy Graham
Thanks Gene. I will try that.
Tommy Graham
#4 Posted : Tuesday, August 23, 2016 5:03:42 AM(UTC)
Tommy Graham
Gene, I drained only a quart of water and the dispenser would shut off, but the flow of water is not much more than a trickle.
#5 Posted : Tuesday, August 23, 2016 1:33:47 PM(UTC)
There is still some air remains in the water system. You have to drain out at least 3 gallons of water.
Water dispenser will not shut off (Refrigerator & Freezer Repair)
by maroondawg67 8/14/2012 11:07:32 AM(UTC)
Water Dispenser will not shut off (Refrigerator & Freezer Repair)
by markbonnoront 11/7/2011 3:46:02 AM(UTC)
by David Ulyicsni 8/29/2011 1:55:05 PM(UTC)
