mindyjoschmid
#1 Posted : Thursday, August 18, 2016 8:57:48 AM(UTC)
mindyjoschmid
I watched the video, and then replaced the Water Valve in my Whirlpool Refrigerator. I plugged it back in, and ran water through to check for leaks. There was a small leak, so I pulled the valve back out to check the tubes, and it was VERY hot. I do not think it should have been that hot! I may have connected the plugs back upside down on the larger size plug. Would that have caused it to get hot enough to burn me? Is it possible I got the wrong part for my model? I checked it a few times before I ordered! But I did wait about a year to install it. :)
I am leery of plugging it back in now, so any advice would help.
