Im looking for a wiring diagram for my amana dlg330raw control panel. I recently took apart my Amana dlg330raw dryer to replace a belt, when I got it back together it flips the breaker as soon as its plugged in. I'm assuming I switched up a wire somewhere in the control panel because those are the only wires i took off. I double checked all the other connections and everythings good there. Any help would be greatly appreciated
Joined: 6/13/2014(UTC) Posts: 781   Was thanked: 1 time(s) in 1 post(s)
