I have a minor (drip) leak that I am 99% is due to the shaft seal for the solenoid (see pics). It looks like the shaft and the metal facing of the solenoid are rusted, but they seem to be functioning fine. Wondering if I should replace the solenoid assembly along with the shaft seal and push-on nut? I am probably replacing the dishwasher entirely in the next 3 or 4 months, so don't want to spend more than necessary. sb65 attached the following image(s):
