vincentdlima
#1 Posted : Thursday, August 11, 2016 9:38:56 AM(UTC)
vincentdlima
When I pres the start button the dryer starts working. The moment I release the start button it stops. But If I keep the start switch pressing it keeps working fine. Completes the cycle.
So please advice what could be the problem.
Thanking you in anticipation.
brobriffin
#2 Posted : Thursday, August 11, 2016 11:57:10 AM(UTC)
brobriffin
Man
United States
The is a problem likely with the centrifugal switch that is suppose to keep the motor running. When the motor gets up to speed a centrifugal switch trips and closes points to complete the run circuit. I would imagine the contacts inside the switch are carboned up or broken.
Please watch this video for more detailed explanation.
https://www.youtube.com/watch?v=CaaqRXQERVc
You will need to replace the motor, here is yours
GE WE17X22217 Kit Motor and Pulley - AppliancePartsPros.com
