I ran a wash cycle with the lid open and the washplate doesn't move independently from the tub. The two move together in the same direction at the same time so there is very little agitation so the clothes don't get clean. I found this video on YouTube https://www.youtube.com/watch?v=1stdNzvWZ4Mand about 4:20 into it you see the washplate spinning rapidly back and forth. Mine doesn't do that and I can't figure out why. I replaced the hub but still have the same problem. Any advice or insight would be greatly appreciated.
Joined: 6/13/2014(UTC) Posts: 781 ![Man Man](/Themes/yafvision/male.gif) ![United States United States](/Content/images/flags/US.png) Was thanked: 1 time(s) in 1 post(s)
Originally Posted by: brobriffin ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I replaced this part about a year ago. Could it break that fast?
Originally Posted by: brobriffin ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I should add that when the actuator went out I got an error code. In the past two months I've been hit with multiple problems and have replaced the belt, capacitor, inlet valves, and hub. I recalibrated the machine and cleared the error codes. Would the splutch give an error code? Someone on another site suggested it might be the gear case. Is the splutch the more likely source of the problem? PS: I just looked at the video on replacing the splutch. If I take the old one off now would I be able to see if it's bad? Would the teeth be stripped?
It may be stripped or the little arm that shifts it may be bad. I doubt the transmission is bad, do you hear any grinding sounds or have you noticed any water leaking underneath or have you seen an oily substance in and around the transmission? If it is agitating both the tub and the agitator plate my suspicion is still either the actuator or the splutch (splined clutch) assembly not operating. In other words the actuator needs to move the splutch to release the tub during agitation mode.....
Originally Posted by: brobriffin ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) It may be stripped or the little arm that shifts it may be bad. I doubt the transmission is bad, do you hear any grinding sounds or have you noticed any water leaking underneath or have you seen an oily substance in and around the transmission? If it is agitating both the tub and the agitator plate my suspicion is still either the actuator or the splutch (splined clutch) assembly not operating. In other words the actuator needs to move the splutch to release the tub during agitation mode..... There's no noise and I haven't noticed any leaks. I'll take a look at the splutch and maybe I'll just replace it and the actuator, too. That will be a lot cheaper than a gear case. Thank you for your help!
Originally Posted by: prof401 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) There's no noise and I haven't noticed any leaks. I'll take a look at the splutch and maybe I'll just replace it and the actuator, too. That will be a lot cheaper than a gear case. Thank you for your help! Epilogue: This turned out to be what techies call an ID Ten T (write it out with the number ten). When I replaced the actuator I failed to attach the splutch arm to the new actuator. Now that that's done the machine is working fine.
I'm glad you were able to solve the issue, thanks for using the APP forum.
