Jaime1955
#1 Posted : Sunday, July 24, 2016 2:52:20 PM(UTC)
Jaime1955
I have replaced al the tub assembly components on this washer (mine), including the Lid Check Switch. But then the clutch and break got stuck and the clip bolt broke. Replaced the clutch and break, re-threaded the clip bolt seat, replaced the bolt and It worked great for a couple weeks... but the replacement lid check switch fail again. The washer then began to take water and spin clockwise only... replaced the the check switch but it kept spinning only and doesn't agitate (it drains ok). I check the clutch and brake and it seems that its gone again (doesn't wind and snap back as it use to); I believe it was defective replacement.
Should I replace the clutch again? Is there anything else that could be causing this?
Your help will be greatly appreciated!
Jaime
