lenn
#1 Posted : Sunday, July 24, 2016 10:14:02 AM(UTC)
lenn
Looking for info on replacing the mode shifter. I have a loud grinding noise when in the adjetate mode, but not in the spin mode.
brobriffin
#2 Posted : Monday, July 25, 2016 5:19:30 AM(UTC)
brobriffin
Man
United States
Here is the part you are asking for.
GE WH05X10014 Mode Shifter Asm - AppliancePartsPros.com
Washer mode shifter help needed (Washer Repair)
by cavie 2/23/2017 11:34:06 AM(UTC)
ge hydrowave mode shifter assembly noise (Washer Repair)
by loudmachine 6/23/2014 1:16:23 PM(UTC)
Attempting to repair Mode Shifter Assembly WH38X10017 (Washer Repair)
by Miguel*Paredes 4/4/2014 5:38:15 PM(UTC)
Bad Mode Shifter or Bad Pressure Switch? (Washer Repair)
by randyowens 2/2/2014 6:01:11 PM(UTC)
Replaced mode shifter, now no spin, agitate or led light (Washer Repair)
by lhurrle 3/1/2013 7:13:51 AM(UTC)
GE washer won't spin or agitate. Motor? Mode shifter? (Washer Repair)
by kzinti83 9/11/2011 4:57:09 PM(UTC)
Mode Shifter Coil and shaft replacement (Washer Repair)
by dave demaio 5/30/2009 4:56:03 AM(UTC)
