The touch panel display is blank. It will beep when a key is pressed but nothing is visible. Would appreciate help troubleshooting or diagnosing the problem. I have the oven out of the cabinet and the top off. All wires are connected and none appear damaged or burned. Checked voltage and both 110v legs are fine. Power from thermal switch is ok. Fuse at control panel (black wire) ohms out ok.
