Hi everyone,
I've been trying to figure out what's going on with my fridge. I have a Whirlpool W8RXEGMWB00 built in 02/2010. Simply stated, one day it completely stopped cooling. I can leave it run all day and it will not drop below room temperature. The fan runs and the light works, however, the compressor is warm, so I am assuming it is not kicking on.
I have tested continuity of the thermostat, which was fine, as well as continuity of the 3 prongs on the compressor, which all were equal, and also power to the inverter board and compressor, which was fine. There is only 1 single red wire that leads to the inverter that I assume is the "trigger wire" so to speak, I am unsure how to test that. I am now stuck as to where to proceed next. Any and all advice would be much appreciated.
I believe I've narrowed it down to the inverter board, or possibly the defrost board (I am not sure if the defrost board would cause this condition or not, or how it could be tested), unless by chance I am missing something else that would cause this.
Thank you in advance!
