AppliancePartsPros.com
Appliance Repair Help
Refrigerator & Freezer Repair
Crosley refrigerator cycles every few minutes, does cool, freezes at +10°
I have a Crosley rear coil refrigerator/freezer that cools and freezes adequately, but it cycles frequently. About every five minutes it comes on, runs for 1 1/2 to 2 minutes and shuts off. The coils on the back never get very warm. Currently, the freezer stays at about +10° F. The refrigerator stays about +40° F. And, here is a weird anomaly. At night it makes a sharp clicking sound when it tries to come on. During the day not so much. Could be that making dinner and refrigerating leftovers means it is open and closed a lot more in the evening. I have checked the line voltage and have found it to be 122 volts, regardless of the time of day.
I have replaced the start relay. Didn't help. I had a repair guy come, who tested the compressor and pronounced it to be OK, and verified that I'd done the relay correctly. The interior of the freezer compartment never frosts up, so the automatic defrost must be working.
Just to complicate matters, I live in a rural area of northwest Wisconsin, where we get power interruptions and storm surges. Back when the unit was only a couple of years old, we had an electrical storm. It quit working, even though it had been surge protected. I had a repair service come and fix it. The technician replaced the relay and billed me $120, half of which was for the 75 mile round trip. At that time I also discovered that the surge protector was burnt out. (After jumping through hoops, the surge protector manufacturer did pay the bill.)
I have been wondering if it could be a thermostat, overload protector, or the cold control dial. Sorry for the length of this post, but I hope that I've included enough info to cut down on the back-and-forth stuff. Thanks.
Originally Posted by: sancheq  ... I live in a rural area of northwest Wisconsin, where we get power interruptions and storm surges. Back when the unit was only a couple of years old, we had an electrical storm. It quit working, even though it had been surge protected. I had a repair service come and fix it. The technician replaced the relay and billed me $120, half of which was for the 75 mile round trip. At that time I also discovered that the surge protector was burnt out. Power outages do not damage an appliance. Newer refrigeration should have a delay circuit so that frequent and repeated power cycling does not damage its compressor. Power outages and surges are two completely different and separate issues. Adjacent protectors do not claim to protect from typically destructive surges. It can even give a surge even more destructive paths into any nearby or attached appliance. Effective protectors also never fail on a surge. Only near zero (undersized) protectors fail. Protection must be at the service entrance with an always required low impedance (ie less than 10 foot) connection to single point earth ground. (That is not receptacle safety ground.) Only effective protectors have that dedicated wire for a low impedance (ie hardwire has no sharp bends) connection to earth. Surges must be earthed BEFORE entering. Otherwise a destructive surge is hunting for earth destructively via all household appliances. And finds a destructive path via only one or some appliances. Protection for any appliance mean all (ie dishwasher, LED and CFL bulbs, recharging electronics, bathroom and kitchen GFCI, furnace, TVs, washing machine, smoke detectors) need that protection. Appliance protection has always been about that destructive current not anywhere inside. Nothing on an appliance power cord even claims to protect from that transient. Previously, a destructive current was via a relay. That is unusual. Damage is more often on electronics that drive a relay. But if damage exists, then that part was in a path from AC mains to earth ground (maybe via pipe that connects to an ice maker or via contact with an electrically conductive floor such as concrete or linoleum). Anything that can might make a connection to earth is on a 'suspect' list.
Thanks for the quick reply, westom. I threw in the stuff about the surges in our supply system, but I don't think that is what's going on. I'm thinking that the Crosley is a very cheaply built refrigerator, and I think that what I have is a control issue. My #1 suspect is the cold/colder dial mechanism. Anything with movable contacts is an Achilles heel in an electrical devise. That is why relays commonly fail...moving parts combined with contacts.
Originally Posted by: sancheq  Anything with movable contacts is an Achilles heel in an electrical devise. A mechanical part that must have hysterisis is a thermostat. These are generally sealed units. However examination may find a screw that can adjust that hysteresis. It should close when temperature rises. Then not open until temperature drops significantly. Your thermostat may have very little hysteresis. Therefore a thermostat will open after slight temperature decrease. Unplug it and leave it to warm inside for at least 10 or more degrees. Then plug it back in. If it runs for a long period, then hysteresis for that thermostat is a prime suspect.
Thanks, <westom>. I'll investigate that. Seems we're thinking along the same lines.
