2 Pages<12
Johnart
#11 Posted : 9 years ago
Johnart
I watched the video and ordered the suspension rod kit from APP. I will let you know if it helped when I get them installed. Thank you for your assistance.
brobriffin
#12 Posted : 9 years ago
brobriffin
Man
United States
That's great Johnart, I really think that will solve the issue. Please reply and let us know the outcome. Thanks for using our forum and shopping APP.
Johnart
#13 Posted : 9 years ago
Johnart
IT WORKED!! I got the parts from APP in a very timely manner. It was an easy install once I figured it out. (I should have watched a video) We have done several loads both large and small loads and have had no issues. Thank you for your assistance!
djarelt
#14 Posted : 7 years ago
djarelt
Originally Posted by: brobriffin Go to Quoted Post
Look underneath the machine at the rotor. See if it looks like oil splatter in the plastic as well as out. Does the machine make a growling noise or sound like a freight train during spin cycle? Your problem may be bad bearings causing the UL code to occur. This true direct drive system has a big problem leaking water past the tub seal wearing out the bearings. If this is the case you can buy the bearing kit here @ Whirlpool W10435302 Bearing and Tub Seal Kit - AppliancePartsPros.com You will need a bearing press as well @ Whirlpool W10447783 Bearing Installation Tool - AppliancePartsPros.com you can see an installation video at this link as well.
When I lift my washer, it does look like oil spatter all over. I have a MVWB450WQ2, which my wife absolutely hates. I am getting the uL code at the 12 minute left mark. I have tested the suspension and they seem fine. The allen nut on the rotor seemed to be tight at well. The washer has been running loud, as if I had a freight train in my basement. Ideas? From what I am reading, it seems like the freight train in probably the bearings needing to be replaced. Correct?
2 Pages<12
