I replaced the drum rollers due to squeeking. Now my dryer will not heat. What did I do wrong?
Only thing I had different with was disconnecting the moisture sensor. Could I have damaged this and caused the dryer to stop heating?
Bypass it with a jumper wire temporarily to rule the sensor out. you may have to take the front cover off to be able to get at the wire connections.
If you have bypassed the the moisture sensor you should check the heating element.
