Water dispenser first failed. Water line is not frozen (tested blowing into it). Then after a time, ice maker stopped working. Water line is not frozen (tested blowing in) Tried testing water valve Part No: W10408179 continuity. Got continuity in the red solenoide but not in the green solenoide. Thought it was bad, oordered this part, but received new part has the same condition. Is the new part oroken as well, or should be continuity only in the red solenoide? Would appreciate any help. Thanks
