chughes2009
#1 Posted : Saturday, June 11, 2016 8:23:02 AM(UTC)
chughes2009
Hello everyone.
I've came here for help cause I'm stumped with this problem. I replaced the ice maker control module after I tested it with the jumper test points. It was dead so I ordered a new one and replaced it.
Now it will make ice, but only for 1 cycle. After it quits, if I raise and then lower the shut off arm it seems to reset it. Then it will run another cycle and I'll have to raise and lower the arm again to reset it again.
I've noticed too that when the motor runs its cycle, about 3/4 through the cycle, the arm will raise up and then fall back down once it completes it's cycle. Not sure if that is normal or not.
any ideas?
