Christian100
#1 Posted : Saturday, October 31, 2009 12:58:48 PM(UTC)
Christian100
Hi, The fridge works as expected. The freezer works fine and the fridge cools good.
The problem is that when the compressor stops, it make asteel loud noise from in side of the compressor.
Do you know how can fixe that ?
Thank you all.
ChrisPolk
#2 Posted : Wednesday, November 4, 2009 6:15:04 AM(UTC)
ChrisPolk
Hello
I am contacting you from Frigidaire concerning the problem you are experiencing with the loud noise coming from the compressor. To control some of the noise we do offer a product called a sound dampening pad that will reduce some of the noise. The part number is Part number: 5303307583
ChrisPolk
#3 Posted : Wednesday, November 4, 2009 2:36:34 PM(UTC)
You probably have a weak spring in the compressor. Sometimes you can fix this by removing the compressor mounting clips and tilting the compressor in a direction that reduces the noise. Then just shim it up with a piece of rubber.
