I'm converting a Kenmore top-bottom refrigerator to a keg fridge. I need to drill a 1" hole in the side of the refrigerator to run my beer lines through to a tap, but I'm afraid of hitting a coolant line. Are my worries valid?
thanx,
shane
Hi Shane,
Good idea! I like it!
On which side and how far from the rear panel of the fridge you need this hole?
If you're facing the front of the fridge, I want to drill a hole on the right side. The location on the right side really doesn't matter to me as long as I don't hit a line. I was thinking about 18" from the back, and about 14" high. Think that will be ok? Thanks for the help.
-shane
Shane,
You can do it.
At this location it's not going to create any problems.
Originally Posted by: Gene Shane,
You can do it.
Gene. Similar question for 363.9762821, though I'm looking closer to the front on the right side. Help?
Originally Posted by: MorrisToddM Similar question for 363.9762821, though I'm looking closer to the front on the right side. Help? I do no think there is anything on your way at this location. Good luck. Gene.
I want to drill a hole in the left side of a Whirlpool Gold Refrigerator GB2FHDXWQ for a beer tap.
Are there any lines on the left side about 50 inches above the floor and 16 inches from the back?
I looked at the parts diagram but am still cautious. It is a bottom mount freezer.
It worked fine. Originally Posted by: Moomba I want to drill a hole in the left side of a Whirlpool Gold Refrigerator GB2FHDXWQ for a beer tap.
