willhelm
#1 Posted : Sunday, February 17, 2008 12:44:47 PM(UTC)
willhelm
The microwave seems to work normally but it does not heat. When I turn it on there is a burnt electrical wire smell coming from the transformer (relay) on the smart board (I opened the panel so I can clearly smell it). I am assuming that I have a bad board. Any input comments are appreciated.
#2 Posted : Monday, February 18, 2008 11:06:24 AM(UTC)
If you're sure the burning smell is coming from the control (smart) board then the problem is there, but before replacing it I would remove the control board from the control panel and check the other side for any burned spots.
- The part number for the control (smart) board is AP3203000
adfadfdas
#3 Posted : Sunday, February 13, 2011 12:35:03 AM(UTC)
adfadfdas
that illustrates wow gold this component! is, ah, I Gucci outlet see this guy Bin Zhang keen Gucci handbags outlet tho' a periodical of acicular wow power leveling but it is a better man! money no wow gold blissful enough, you see me and your dad.
