hi ive had a problem with my display and so decided to clean circuit boards to see if it would help!! now i'm stuck with 4 wires and 6 connections on the main board!! (didn't label well enough) The board ports ae R1,R2,R3,R4,RL and one other. The wires go to top oven light.bottom oven light,bottom oven cooling fan and bottom oven element!! please let me know asap if you can help as i have now put it out of action!!!!!:(
Hi BISH,
The model number you posted is incorrect.
Verify and repost it, please.
