dredforce
#1 Posted : Friday, May 20, 2016 2:17:32 PM(UTC)
dredforce
Greetings,
I have a Whirlpool Accubake Gold Electric Range, model number GR475LXLS. The front right surface element is not working. I have checked for continuity for both the infinity switch and the heating element, both failed the test. I have replaced the infinity switch but I am at a loss as to what part I need to order for the surface element.
There seems to be three different sizes of surface elements for this particular stove. The larger, duo heating element, the two smaller ones in the back, and the medium sized one, which is the right front element that is currently broken. Please advice.
Thank you very much,
Henry
