I'm not really sure the age. It was purchased for a house being sold that didn't have a range. Once it was plugged in and tested, only the burners work! There is no power or function of the oven or the control panel/clock on the top of the range. Is there an easy fix(loose wire or fuse?) or should it just tossed and get a new one?!
