tracigarner68
#1 Posted : Saturday, April 30, 2016 9:59:00 AM(UTC)
tracigarner68
I have a Maytag Centennial washer that started spinning very fast (much faster than it did before) a few months ago. It then stopped spinning and agitating completely. I replaced the shift actuator, and the washer functions again now, but the spin cycle is still scary fast. Also, since replacing the part, the tub seems to be off balance; when filling, some water runs behind the tub and leaks out underneath the unit. I thought maybe the band that supports the tub was stuck from having the washer laying on its front, but it seems to be okay. Any thoughts?
Appliance Medics
#2 Posted : Saturday, April 30, 2016 10:03:24 AM(UTC)
Appliance Medics
When replacing an actuator you have to enter diagnostic mode and Re calibrate your washer. That may help also make sure the shocks aren't seized or blown
