hello , please help ! every time this washer spin cycles bangs and sounds like its out of balance , I have checked the drum retainer straps and there not broken yet ! What causes this .
Most commonly is one of the 4 tub straps are broken, could have a shock that fell off or is bad, could have a clogged pressure switch hose and is spinning before it's empty, or it could be unlevel. All of which can cause similar problems.
