Foot Stomper
#1 Posted : Saturday, April 23, 2016 9:23:01 AM(UTC)
Foot Stomper
Door latch won't hold so ordered a new one part number 8198380, installed it, it has not improved my problem at all.
The door barely holds the latch, recently, the door would pop open during a cycle, we'd puch it closed, hit start and away it go go again... now it won't hold the door at all. As soon as I release pressure on the door, it pops open. The latch is trying to hold, but can't.
I've tried bending the latch ring that is mounted to the unit but that didn't help at all.
This seems so strange! If I hold the latch and latch ring in my hand, I can see how it should work, but after installing everything, it doesn't hold the door.
Very recently I replaced a door roller string at the bottom that supports the weight of the door... could something be wrong with my install? The door opens smoothly, no noise, easy up and easy down...perfect operation.
[IMG]https://goo.gl/photos/giUVjqvjD4SezY746[/IMG]
Foot Stomper
#2 Posted : Saturday, April 23, 2016 9:24:20 AM(UTC)
Foot Stomper
