Please advise how to replace gasket - do I just press into groove or do I have to pull out oven liner to install? Also, please advise on model/part # of gasket I can use since I can't find one that looks like the original.
As FYI, I was able to replace the gasket by loosening the 2 bolts on the back of the range and pulling the oven liner out about 1/2 inch. Gasket part number WB2X1522 is the correct replacement part.
As FYI, I was able to replace the gasket by loosening the 2 bolts sticking out of the back of the range and pulling out the oven liner about 1/2 inch. Gasket part number WB2X1522 is the correct replacement part.
