mse277
#1 Posted : Saturday, October 31, 2009 5:18:31 AM(UTC)
mse277
My maytag washer will spin but no water will enter the washer basin when I turn it on. How can I get the water into the basin? Thank you.
sidfink43
#2 Posted : Sunday, November 1, 2009 7:47:35 AM(UTC)
sidfink43
You need to see if 120v is getting to the water valves when it is supposed to be filling. If so, replace the valve assembly.
If not take a look at your water level switch and the wiring between it and the timer, but the most likely problem will be in the timer which directs current to the valve assembly.
