There are no lights on the control panel.
When I press any button or push the water dispenser, all the lights come on including the digital display (8.8.8. 8.8.8.). All the lights go out when I take my finger off of a button.
When I press the water dispenser, it also beeps.
The lights work inside the fridge, but it is not cooling or freezing.
I tried the programming codes, but that didn't work.
Is this a bad board or can something else cause this? Is there a way to reset it?
Does anyone have a service manual for this model?
Thanks!!
I have the exact same issue. What was wrong with your unit?
Hi, did you ever figure out what was wrong with your fridge? I have the same exact issue
