cheevang77@gmail.com
#1 Posted : Thursday, March 31, 2016 9:52:35 PM(UTC)
Please help. My GE Profile French Door stop cooling completely. I don't hear the compressor coming on and the fan is spinning. What are your thoughts form members. Thanks in advance :D
cbmserviceguy
#2 Posted : Friday, April 1, 2016 9:51:55 AM(UTC)
cbmserviceguy
I would start with the compressor relay. Take it off, shake it and see if it rattles. If it does, you need a new relay. If it doesn't, or you aren't sure, check to see if the control is supplying 120vac to the relay. If it is, check windings for ohms to rule out compressor. If that checks out, you need a relay. If there is no power supplied, you need a control board.
