When I woke this morning, I heard the stand alone ice machine filling with water, then the pump came on to drain. The water continued to run filling the reservoir and the pump continued to drain.
I have unplugged the unit, waited 30 sec and plugged back on similar to a computer reboot?
Is there any tests I can perform to isolate an issue or is there a part I need to remedy this?
Thank you in advance for any help I can get on this issue.
