krupp
#1 Posted : 9 years ago
krupp
Came home from spring break vacation and display on oven not working. Beeps when buttons pressed. Light comes on. Can't turn on oven, series of beeps when start is pressed. Have read on this site that it could be the control panel but just wanted some reassurance before ordering parts.
Please advise. Thank you.
krupp
#2 Posted : 9 years ago
krupp
Purchased a new control panel, part #W10438750. All connections matched, installed and switched the breaker back on. Display now works, things function and oven turns on.
However, oven "off" buttons do not work! Can't turn off the darn thing.
Took off and reconnected the ribbon connector between the touch glass and the board. Still no luck.
Could it be I have the wrong part? P/N on a sticker on the old control panel is 8303883. Things look slightly different on the back of the panel. Or, is there something else I should do?
Whirlpool Double Oven Display blank... (Oven Repair (including Ranges and Cooktops))
by LuckyLynn 14 years ago
