The Ice Maker will not produce ice. I can cycle a "harvest" and water will flow into the tray, but then nothing. The water will freeze, but the ice maker will not "harvest" the ice on its own.
Both, water and ice dispensers work. The water line is not froze.
Any ideas?
Okay....so I gave this post a day to simmer without any replies.
I'm going to take a guess at this. The issue is probably caused by a part or a combination of parts inside the ice maker itself, which cannot be purchased individually or if they were purchased individually would not be worth the time or effort of the disassembly and reassembly of the ice maker. So, the best option would be to just purchase a replacement ice maker for $90.
Okay....good talk.
Thanks for the assistance with this issue. I'll let you know how it goes.
