my 3 pins are not labeled, here are the ohm readings, AB-19.4, AC, 23.3, BC-4.5, please help me identify which one is start run and common. thank you
I can't remember which is which for start/run, but common is the pin by itself, not beside a pin. So being in the shape of a pyramid, the common would be the tip. You need to check ohms from each of the other two to common, then from each of other two to the case. Hope this helps!
