Tattoed Hunter
#1 Posted : Wednesday, March 16, 2016 3:53:11 AM(UTC)
Tattoed Hunter
Purchased the washer about 2 years ago but recently it started having a problem. When you run a load if you are not standing there and lift the lid as soon as it is done, it will start a new wash cycle by itself. I was able to open the machine and pull the tech sheet and get the error code. I am getting the error code F2 E1 which is saying stuck key. There is no mention of how to fix this. That is why I am here. I need a solution on fixing this problem. Thank you.
