nickk678
#1 Posted : Wednesday, March 9, 2016 5:29:59 PM(UTC)
nickk678
Hi guys,
I have a Kenmore side by side fridge that I assumed had a bad baffle (fridge would on and off start to freeze as the temperature in the house warmed up at the change of seasons, thought maybe it was freezing). However, today I popped a thermometer in teh freezer and the temperature is ~-15F (fridge is at ~30F) - I think the thing is running on overdrive!
Anyway, I'm guessing it's a thermistor or main board? Can anyone weigh in? If so, where are they located and how can I check? I tried to use the diagnostic mode using the front control panel, but I think one of the buttons is bad as I cannot get it
Nick K.to access diagnostic mode, so assuming I'll have to fix it the old fashion way.
Thanks,
nickk678
#2 Posted : Sunday, March 27, 2016 4:53:33 AM(UTC)
nickk678
Hi guys,
Checking in again to see what you guys think.
The problem went away for a couple weeks, and just this weekend everything is frozen again in the fridge.
