Hello,
Without warning while baking : oven will reset, blinking clock, etc. Not good.
Considering the replacement of the oven control board but can't find R&M manual on particular model of oven to see if power supply is seperate from Control Board.
Thought process being, if DC conditions to Control Board are not good, then a new board will not solve a damn thing !
2011, year of manufacture, no error codes listed in care and feeding manual therefore oven incapable of SOME self diagnosis.
Please please advise when able.
Thanks, Todd
The presence of relays / surge suppression along the one side of circuit board makes me think the power supply is part of the Control Board.
Rank: Guest
Joined: 8/10/2018(UTC) Posts: 0  Location: 99556 Was thanked: 4 time(s) in 4 post(s)
Would need some help on where to find the correct parts numbers for the Sears Elite Model: C970-419431 Double Oven. I believe the manufacturer is Frigidaire.
The black outer glass on the door, which appear to be glued to two stainless steel panels shattered whilst I was trying to tighten a loose screw on the door handle. ITs for the upper door. Any help would be greatly appreciated
